achaccha
Весь контент achaccha
  1. I'm installing EcuFlasher on a Windows 11 PC. After completing the installation, I connected the dongle, and when I open the application, I get the message: "Sorry, this application cannot run in a virtual machine." I checked the virtual machine compatibility settings, as Krox suggested in his post, and I see that this function is disabled on my PC, as shown in the attached image. However, I'm still getting the same message, and EcuFlasher isn't working. Can you please help me? Thanks
  2. Dear Friends Please I need to better understand this ECUFLASHER tool. Today when I entered I saw that there is an update of MT92.1 and MT92.E ecu Delphi. my intention is to read the MT92.1E Ecu of Chinese JAC car. can you tell me if Ecuflasher can read and write to this ecu? which license should i buy? I have the Tricore license that I bought to read SID208 from Peugeot, I am not sure if this license works for MT92.1E Entering the software with my dongle, how can I know the licenses that I have active in my Ecuflasher? Does the license to read MT92.1E read only by OBD2 or do you have to uncover the ecu? I need more information about it please Thank you
  3. Happy New Year 2021 to all, much prosperity and good health to all
  4. Dear Friend You who have experience in this SID208, suggest to make the change in the ecu or suggest to do it in the BCM-IMMO. if I modify in the BCM-IMMO I think that the original key will not work. or I'm wrong? I say this because I have modified the 6 Bytes in the ecu and it has not worked for me. you have the last word friend, for your experience in these cases thanks for your help
  5. Dear Friends. I recently tried to read a 2011 Audi A4 TCM "VL381" with ecuflasher. I have tried with direct connection but it was not possible to get the reading. has anyone been able to read a similar TCM with ecuflasher? Now everything is paralyzed by a quarantine decreed by our national government. As soon as I get back to work I will keep trying and I need your help to do it. take care of yourselves friends
  6. Querido amigo He comprado la licencia PSA SID208 para ecuflasher, pero hasta ahora no he podido leer la contraseña del ecu en el banco. La lectura que publiqué se realizó con Ktag. El ecu que estoy leyendo la contraseña es el que se muestra en la imagen, la conexión que estoy usando también está en otra imagen. puede ser una conexión diferente para leer la contraseña y otra conexión para leer el ecu. Espero tus comentarios. saludos amigos
  7. Dear Friend I have purchased the SID208 PSA license for ecuflasher, but so far I have not been able to read the pasword of the ecu in bank. The reading I published was done with Ktag. The ecu I am reading the pasword is the one shown in the image, the connection I am using is also in another image. it may be different connection to read pasword and another connection to read ecu. I await your comments. greetings friends
  8. Dear friends: I have a 2017 Peugeot Boxer, I need to install a used ecu. The original ecu has been lost. Will it be possible to clone the ECU (SID208) and BSI (95640) of a perfectly functioning vehicle? In any case, will it be possible to obtain the pin code of the donor ecu(SID208)? I also want to know if it is possible to make this ecu virgin (SID208).I await your comments please, I need to find a solution to start this Boxer 2017 engine.thanks for your help Дорогие друзья! У меня есть Peugeot Boxer 2017, мне нужно установить использованный компьютер. Оригинальный компьютер был потерян. Удастся ли клонировать ЭБУ (SID208) и BSI (95640) идеально работающего транспортного средства? В любом случае, можно ли будет получить пин-код донорского ЭБУ (SID208)? Я также хочу знать, возможно ли сделать этот ecu virgin (SID208).Я жду ваших комментариев, пожалуйста, мне нужно найти решение для запуска этого двигателя Boxer 2017 года.Спасибо за вашу помощь PEUGEOT BOXER 2017.rar
  9. Dear Friends. I write to consult if this software, only works with Tactrix? Is there any other tool that also works with the software? thank you for your comment
