ECU/Kia/Soul/1.6 16V/Bosch ME17.9.11 TC1762 1504kb CAN BUS
Dear Sir ,
I had faced an issue on writing mod file via OBD , when i writing mod file the car wont start and it give SOFTWARE VERSION: 20202020202020202020202020202020,
when i write stock , everything is fine , i had written the mod file via boot mode it works well, anything need to be updated ?
Thank You
log.txt
Ссылка на комментарий
https://ecuflash.ru/forum/topic/710-ecukiasoul16-16vbosch-me17911-tc1762-1504kb-can-bus/
Поделиться на другие сайты
you flashed the incorrect firmware, try to do the tuning from this dump
GAYD-CE46QS01C00.rar
https://ecuflash.ru/forum/topic/710-ecukiasoul16-16vbosch-me17911-tc1762-1504kb-can-bus/#findComment-8834
i see the different in 17F02-17F73 , what is the issue ? as the tuned firmware was loaded from the ECU by boot mode .
https://ecuflash.ru/forum/topic/710-ecukiasoul16-16vbosch-me17911-tc1762-1504kb-can-bus/#findComment-8835
